2.4 View and Edit Repricing Pattern
You can view existing Repricing Pattern, and you can edit existing patterns, provided you have Read/Write privileges.
To view and edit a Repricing Pattern, follow these steps:
- Navigate to the Maintenance and select Repricing Pattern.
- Search for a Rule. For further information, see the Searching for Rules section.
- Click on the Action icon against the Pattern Name and select View/Edit to open the rule you want to update.
- Update the Rule details.
- Click Apply or Save, depending on the Rule type.
