2.1 Repricing Pattern Summary Page
This page is the gateway to all Repricing Patterns and related functionality. You can navigate to other pages relating to Repricing Patterns from this point.
The Cash Flow Repricing Summary Page displays the following columns.
Table: Repricing Pattern Rule – Fields and Descriptions
| Column | Description |
| Name | Displays the Repricing Pattern Rule's Short Name. Mouse over the Name field to view the Code and Description details. |
| Pattern Type | Displays the Repricing Pattern Type, such as Absolute or Relative. |
| Created By | Displays the Name of the user who created the Repricing Pattern. |
| Created Date | Displays the Date and Time at which a Repricing Pattern was created. |
| Last Modified By | Displays the Name of the user who last modified the Repricing Pattern Rule. |
| Last Modified Date | Displays the Date and Time when Repricing Pattern was modified last. |
| Action | Displays the list of actions that can be performed on the Repricing Pattern Rule. For more information, see Repricing Pattern – Icons and Descriptions . |
Figure 2-1 Repricing Summary Page
The Action column on the Repricing Pattern Summary Page offers several actions that allow you to perform different functions. The following actions are available for the Repricing Pattern Rule.
Table: Repricing Pattern Rule – Icons and Descriptions
Table 2-1 Repricing Pattern – Icons and Descriptions
| Fields | Description |
Add |
Click Add icon to build a new Repricing Pattern Rule. |
| Multiple Delete | Select one or more rules in the table and then click the (-) icon at the top right of the Summary Page to delete more than one rule at the same time. |
View/Edit |
Click on the Action icon against the Pattern Name and select View/Edit to view or edit the contents of a Repricing Pattern Rule in Read/Write format. Depending on User Privileges the rule will open in either View or Edit Mode. |
| Save As | Click on the Action icon against the Pattern Name and select Save As to create a copy of an existing Repricing Pattern Rule. |
| Delete | Click on the Action icon against the Pattern Name and select Delete to delete an existing Repricing Pattern Rule. |
| Dependency Check | Click on the Action icon against the Pattern Name and select Dependency Check to view objects where selected Repricing Pattern Rule is used. |
