5.3.3.1.2 Define Currency Forecast Methods
The following Currency Forecast methods are available when you select a currency (other than the reporting currency) from the Currency Codes list. Currency forecast methods is available in Asset Liability Management Cloud Service only.
Figure 5-68 Currency Forecast Methods
Table 5-16 Currency Forecast Methods
Method
Description
Flat Forecast no change in the exchange rate for all dates beginning with the as-of date.
Structured Change Forecast exchange rates as an incremental change from the previous period.
Direct Input Type exchange rates to use in forecasting.
Parity Forecast the exchange rate between two currencies based on forecasted interest rate associated with the currencies. The parity method can be used only if both the reporting currency and the selected currency have a Reference IRC. If reference IRC is not available for both or any one currency then flat method is used.
No Arbitrage Forecast the exchange rate required to maintain a no-arbitrage condition between two currencies. The No Arbitrage method can be used only if both the reporting currency and the selected currency have a Reference IRC. If reference IRC is not available for both or any one currency then flat method is used.
Following options are available for Currency Forecast Rule:
Define
  • Flat Method
    1. Select Currency Code using corresponding checkbox and select Forecast Method as Flat.
    2. Input Minimum Rate, if required.
    3. Click Define.
    4. The status of the Currency Code is changed to Defined.
  • Direct Input
    1. Select Currency Code using corresponding checkbox and select Forecast Method as Direct Input.
    3. Click Define. The Direct Input window is displayed:
      Figure 5-69 Direct Input window
      Direct Input window
    4. Right click on data grid and select ‘Export to excel’ to save visible data to excel file. You can also copy directly from the grid and paste data from an excel file to the grid. Enter data and click Apply.
    5. The status of the Currency Code is changed to Defined.
  • Structured Change
    1. Select Currency Code using corresponding checkbox and select Forecast Method as Structured Change.
    3. Click Define. The Structured Change window is displayed:
      Figure 5-70 Structured Change window
    4. Select the Shock Type as Rate or Percent. Shock Type as Rate designates to absolute rate change and Shock Type as Percent designates to percent rate change.
    5. Enter Start and End period from 1 to 360 months and corresponding shock amount to apply to the Currency. Right click on data grid to all more rows or delete rows. Use the Excel Import or Export feature to add the interest rate changes. Click Apply.
    6. The status of the Currency Code is changed to Defined.
  • Parity
    1. Select Currency Code using corresponding checkbox and select Forecast Method as Parity.
    3. Click Define.
  • No Arbitrage
    1. Select Currency Code using corresponding checkbox and select Forecast Method as No Arbitrage.
    3. Click Define.
Copy Across
This allows you to copy Forecast Method and related details from one Currency to another.
For example, if you have 10 Currency codes enabled in the application and you must input only one set of assumptions, then copy those assumptions across all enabled Currency codes, instead of having to input 10 full sets, thereby saving a significant amount of input time.
You must select a defined Currency to use Copy Across. For more information, see the Define section of Currency.
  • Flat Method
    2. Click Copy Across.
    3. Click Apply Copy Across.
    4. You can click Cancel Copy Across to cancel the Copy Across function.
  • Structured Change
  • Parity
  • No Arbitrage
Restore Default
Use this action to reset previously entered details to Undefined status.
  • Flat Method
    2. Click Restore Default.
    3. The status of the Currency Code is changed to Undefined.
  • Direct Input
  • Structured Change
  • Parity
  • No Arbitrage
View
After defining Forecast Method and other parameters for a Currency you can view the forecasted Currency by clicking this button.
  • Flat Method
    2. Click View to see the output table.
  • Direct Input
    2. Click View to see the Output Table.
  • Structured Change
  • Parity
  • No Arbitrage
