Interest Rate Forecast Methods
The IRCs for all active currencies are listed under Interest Rate Curve section. The options under Interest Rate Curve Forecast Method provide multiple ways to model the effects on portfolio Cash Flows due to Interest Rate changes.
Figure 6-97 Interest Rate Curve Forecast Rates
You can define Interest Rate Forecast for the following methods:
Table 6-22 Forecast Rate rule – Methods and Descriptions
Method Description
Flat Forecast no change in the Interest Rate for all dates beginning with the As-of Date.
Direct Input Type Interest Rates directly for any modeling period or Interest Rate term.
Structured Change
Forecast exchange rates as an incremental change from the previous period. Forecast rate changes in terms of absolute or percent change, for any modeling period or interest rate term, such as:
+100 basis points on Day 1
-200 basis points over the first 6 months
Yield curve rotation (short point decreasing, long point increasing).
This option is available only in Asset Liability Management Cloud Service.
Implied Forward
Forecast interest rates based on the yield-curve interest rates in effect at the as-of date and consistent with the modeling bucket definitions.
Yield Curve Twist Flatten or steepen the yield curve around a specific point on the curve.
Change from Base
Make incremental changes to an existing forecast scenario.
IRRBB Standardized Approach Shocks
Forecast an interest rate shock according to one of the BCBS IRRBB Standardized Approach shock specifications (Scenario-level specification).
IRRBB Enhanced Approach Shocks
Forecast an interest rate shock according to user specifications that will flow into IRRBB Table B reporting.
Formula
Hybrid and Managed Rate IRC can be forecasted using the formula defined in Managed Rate/ Hybrid section of IRC.
Formula method is applicable to Hybrid and Managed Rates IRC.
For more information, see the Cash Flow Engine Reference Guide.
The following Interpolation Methods are available.
Table 6-23 Forecast Rate Rule – Interpolation Methods and Descriptions
Method Description
Linear Interpolation Linear interpolation uses Linear Yield Curve smoothing. Linear Yield Curves are continuous but not smooth; at each knot point, there is a kink in the yield curve. You may not want to use a Linear Yield Curve with a model that assumes the existence of a continuous Forward Rate Curve, due to the nonlinear and discontinuous knot points of a Linear Yield Curve.
Cubic Spline of Yields
A cubic spline is a series of third-degree polynomials that have the form:
y = a + bx + cx2 + dx3
These polynomials are used to connect the dots formed by observable data. The polynomials are constrained so they fit together smoothly at each knot point (the observable data point.) This means that the slope and the rate of change in the slope with respect to time to maturity have to be equal for each polynomial at the knot point where they join. If this is not true, there is a kink in the yield curve and they are continuous but not differentiable.
Two more constraints make the Cubic Spline Curve unique. The first restricts the zero-maturity yield to equal the 1-day interest rate. The second restricts the yield curve at the longest maturity to be either straight (y"=0) or flat (y'=0).
Quartic Spline
Quartic interpolation requires a minimum of 4 knot points. The quartic interpolation equation can be represented as:
Y = a + bX + cX2 + dX3 + eX4
The end knot points satisfy equations for one curve and all intermediate points satisfy two curves. Therefore, in a scenario with a minimum number of knot points, there are 6 equations. For n number of knot points, the number of equations is 2n-2. If n is the number of points to be interpolated, the order of the matrix to be formed is 5*(n-1) x 5*(n-1). The matrix is formed according to the following logic:
The second derivative at the endpoints and the first derivative of the last point is Zero. At the points other than the endpoints, the value of the first derivatives, second derivatives, and the third derivatives of the function are equal.
In looking up the Forecast Rates, the Cash Flow Engine (where necessary) performs an interpolation between yield curve term points. For example, in determining a three-month rate from a yield curve that contains only a one-month rate and a six-month rate, the Cash Flow Engine performs an interpolation to determine the implied three-month rate. The Interpolation method used is defined by the selected interpolation method for the Interest Rate Curve.
Forecast rates for 360 calendar months starting from As-of-Date are generated.
Following options are available for Interest Rate Curve Forecast Rule:
Define
  • Flat Method
    1. Select Interest Rate Curve using corresponding checkbox and select Forecast Method as Flat.
    2. Select the Interpolation method.
    3. Input Minimum Rate, if required.
    4. Click Define.
      The status of the Interest Rate Curve is changed to Defined.
  • Direct Input
    1. Select Interest Rate Curve using corresponding checkbox and select Forecast Method as Direct Input.
    2. Select the Interpolation Method.
    4. Click Define.
      The Direct Input window is displayed:
      Figure 6-98 Direct Input
      Direct Input
    5. Enter data and click Apply. Right click on data grid and select ‘Export to Excel’ to save visible data to excel file. You can also copy directly from the grid and paste data from an excel file to the grid.
    6. The status of the Interest Rate Curve is changed to Defined.
  • Structured Change
    1. Select Interest Rate Curve using corresponding checkbox and select Forecast Method as Structured Change .
    4. Click Define.
      The Structured Change window is displayed:
      Figure 6-99 Structured Change
      Structured Change
    5. Select the Shock Type as Rate or Percent. Shock Type as Rate designates to absolute rate change and Shock Type as Percent designates to percent rate change.
    6. Enter a shock amount to apply to the IRC in absolute rate or percentage change. Enter Start and End period from 1 to 360 months and corresponding shock amount to apply to the IRC. Right click on data grid to all more rows or delete rows. Use the Excel Import or Export feature to add the interest rate changes.
    7. Click Apply to save.
    8. The status of the Interest Rate Curve is changed to Defined.
  • Implied Forward
    1. Select Interest Rate Curve using corresponding checkbox and select Forecast Method as Implied Forward.
    4. Click Define.
      The Implied Forward window is displayed:
      Figure 6-100 Implied Forward
      Implied Forward
    6. Enter a shock amount to apply to the IRC in absolute rate or percentage change. If no change is required to the base curve, leave at 0.0, and click Apply.
    7. The status of the Interest Rate Curve is changed to Defined.
  • Yield Curve Twist
    1. Select Interest Rate Curve using corresponding checkbox and select Forecast Method as Yield Curve Twist.
    4. Click Define.
      The Yield Curve Twist window is displayed:
      Figure 6-101 Yield Curve Twist
      Yield Curve Twist
    5. Select Start and End Period. Start Period must 1 or higher while highest End Period can be 360.
    6. Select the tenors using the Short Point, Mid Point, and Long Point.
    7. Add the required shock amounts for each tenor. At runtime and display time, the rate changes are added to the As-of-Date rates to create a future scenario.
    8. Click Apply.
  • Change From Base
    This method is available from second scenario onwards.
    1. Select Scenario 2 or higher as Scenario.
      Figure 6-102 Change From Base
      Change From Base
    2. Select Interest Rate Code using corresponding checkbox and select Forecast Method as Change from Base.
    3. Select the Interpolation Method.
    4. Input Minimum Rate, if required.
    5. Click Define. The Change From Base window is displayed.
      Figure 6-103 Change From Base
      Change From Base
    6. Scenario 1 is used as base scenario.
    7. Enter the Forecast Period from 1 to 360 months and the corresponding change amount to apply to the base forecasts IRC. Right click on data grid to all more rows or delete rows. Use the Excel Import or Export feature to add the interest rate changes.
  • Standardized Approach Shocks
    Standardized Approach shocks are different than other Interest Rate Rules as these are applied at the scenario level instead of at the IRC level. When you create a new Forecast Rates rule, update the IRC Forecast Method for IRRBB Shocks Scenarios.
    1. In Forecast Rates window, select the IRRBB Shocks. This allows you to define either Standardized or Enhanced Approach Scenarios, or both for a single Forecast Rates Rule. Once a forecast rates rule is designated as IRRBB Shocks, this checkbox cannot be unselected unless there are no defined scenarios as either Standardized or Enhanced Approach scenario type.
    2. To apply a Standardized Approach scenario, click the Add Scenario.
    3. In the Add Forecast Rates Scenario section, select the Scenario Type to apply the scenario. The following are the shock scenarios:
      • Standardized Approach Shock - Parallel UP
      • Standardized Approach Shock - Parallel DOWN
      • Standardized Approach Shock - Short UP
      • Standardized Approach Shock - Short DOWN
      • Standardized Approach Shock - Flattener
      • Standardized Approach Shock - Steppener
    4. Only one Standardized Approach shock can be applied to a single scenario, and no two SA shocks of the same type may be applied to the same Forecast Rates rule. All qualifying IRCs will inherit this SA shock and cannot be changed except for their interpolation method and minimum rate.
    5. Click Apply to make scenario as Standardized Approach shock.
  • Enhanced Approach Shocks
    Like Standardized Approach shocks, Enhanced Approach shocks are scenario-level rules. When you create a new Forecast Rates rule, update the IRC Forecast Method for IRRBB Shocks Scenarios. However, unlike Standardized Approach shocks, the Forecast method for each IRC is not pre-established. This means that users must define the Forecast method, interpolation method and minimum rate for all Interest Rates in each scenario. Once defined and processed, the results will flow through into the Table B reporting.
    1. In the Forecast Rates window, select the IRRBB Shocks. This allows you to define either Standardized or Enhanced Approach scenarios, or both for a single Forecast Rate rule. After a Forecast Rate rule is designated as IRRBB Shocks, this checkbox cannot be unselected unless there are no defined scenarios as either Standardized or Enhanced Approach Scenario Type.
    2. To apply an Enhanced Approach scenario, click the Add Scenario. The following are the shock scenarios:
      1. Enhanced Approach Shock - Parallel UP
      2. Enhanced Approach Shock - Parallel DOWN
      3. Enhanced Approach Shock - Short UP
      4. Enhanced Approach Shock - Short DOWN
      5. Enhanced Approach Shock - Flattener
      6. Enhanced Approach Shock - Steppener
    3. Only one Enhanced Approach shock can be applied to a single scenario, and no two EA shocks of the same type can be applied to the same Forecast Rates rule. All IRCs in this scenario remain fully editable for the Forecast method, Interpolation method, and Minimum Rate.
    4. Click Apply to make the scenario as Enhanced Approach shock.
  • Formula
    This method is applicable for Hybrid and Managed Rate IRC definitions. For Hybrid and Managed Rate IRC definitions, following methods are applicable: Flat, Formula, and Direct Method.
    1. Select Interest Rate Curve using corresponding checkbox and select Forecast Method as Formula.
    4. Click Define.
    5. The status of the Interest Rate Curve is changed to Defined.
Copy Across
This allows you to copy Forecast Method and related details from one IRC to another.
For example, if you have 10 IRCs enabled in the application and you must input only one set of assumptions, then copy those assumptions across all enabled IRCs, instead of having to input 10 full sets, thereby saving a significant amount of input time.
You must select a defined IRC to Copy Across. For more information, see the Define section of Interest Rate Curve.
  • Flat Method
    2. Click Copy Across.
    3. Click Apply Copy Across.
    4. You can click Cancel Copy Across to cancel the Copy Across function.
  • Structured Change
    1. Select Interest Rate Curve using the corresponding checkbox and select Forecast Method as Structured Change..
  • Implied Forward
  • Change From Base
    1. Select Interest Rate Curve using corresponding checkbox and select Forecast Method as Change From Base.
  • Formula
Restore Default
Use this action to reset previously entered details to Undefined status.
  • Flat Method
    2. Click Restore Default.
    3. The status of the Interest Rate Curve is changed to Undefined.
  • Direct Input
  • Structured Change
    1. Select Interest Rate Curve using corresponding checkbox and select Forecast Method as Structured Change.
  • Implied Forward
  • Yield Curve Twist
  • Change From Base
  • Formula
View
After defining Forecast Method and other parameters for an IRC you can view the forecasted interest rates by clicking this button.
  • Flat Method
    2. Click View to see the output table.
  • Direct Input
    2. Click View to see the Output Table.
  • Structured Change
  • Yield Curve Twist
  • Implied Forward
  • Change From Base
  • Formula
