Executing a Lookup Table using Scheduler Service To execute a Lookup Table using Scheduler Service: Navigate to Scheduler Service, select Define Batch Click Create from Actions. Create a batch and save it. Navigate to Scheduler Service, select Define Task. Create a task. Select the Component as Lookup Table and click Save. In the Task Parameter section, enter the following values: Table 4-26 Lookup Table Parameters Parameter Description Folder Select the folder used to filter and locate the Lookup Table rule. Lookup Table Rule Select the Lookup Table rule to execute or process. Save the task and add it to the batch. Execute the batch with the required As of Date. Monitor the task. For more information, see For more details, see Monitor Batch.. Navigate to the Lookup Table summary screen and review the execution status and log details for the selected Lookup Table rule.
