3.3.1 Accessing Admin Console
Access Admin Console from the home page of Financial Services Analytical Applications.
To access the Admin Console, ensure that the cloud administrator grants you administrative privileges by mapping your user account to the Identity Administrator and Identity Authorizer user groups. These user groups are seeded in Oracle Identity and Access Managment (IAM).
Before logging into the Admin Console, ensure that:
  • If the Cloud Administrator has granted only Identity Management privileges and no other cloud application privilege, you will be automatically redirected to the Admin Console specific to subscribed cloud service, after a successful login.
  • After a user signs in to the Cloud Service, the user to user-group Mapping created in the IAM Console will onboard into the Master and Mapping Tables. If you unmap a user from a group in the Admin Console, go to the IAM Console and open the Assign User to Groups. Unselect the user corresponding to the user group and click Finish. This step is mandatory to unmap the user.
To access the Admin Console:
  1. Enter the application URL in the browser's address bar to access the Oracle Cloud Account Sign In page.
  2. Enter the username and password on the Login page to log in to the Financial Services Analytical Applications.
    After successfully logging in, you can view the Financial Services Analytical Applications homepage and the list of subscribed cloud applications. Click Navigation to hide the Applications Navigation List.
  3. Click Admin Console at the top of the Financial Services Analytical Applications home page.
    In the Admin Console, you can view the System Configuration and Identity Management tabs. Use these tabs to perform the following tasks:
    • Administrator Tasks:
      • View the Metering Report, Audit Trial Report, Object Storage, and Object Authentication (OAUTH) credential details in the System Configuration tab.
      • Perform the Identity and Access Management operations in the Identity Management tab.
    • Authorizer Tasks:
      • Authorize the Identity and Access Management Operations in the Identity Management tab.
    Role-Based Access
    Access to Admin Console functionalities is controlled through role-based function mappings. The System Configuration and Identity Management options are displayed only if the user has the corresponding role and function mapping assigned (as shown in the table below). You can customize access to each Admin Console functionality by assigning appropriate role-function mappings. As a result, each administrator may have access only to specific functionalities based on their assigned role.
    Admin Console functionality Required Function Code/Function Name Required Role Code (Role Name)
    System Configuration Tile ADMIN_SYS_UI (Admin System Config Tile) ADMIN_SYS_UI (Admin System Config Tile Role)
    Identity Management Tile ADMIN_IDNTY_UI (Admin Identity Config Tile) ADMIN_IDNTY_UI (Admin Config Tile Role)
    Configurations ADMN_CONFIG_UI (Admin Configuration Viewer) ADMN_CONFIG_UI (Admin Configuration Viewer Role)
    Component Details ADMN_COMPONENT_UI (Admin Component Details Viewer) ADMN_COMPONENT_UI (Admin Component Details Viewer Role)
    User Report ADMN_USR_REPORT_UI (Admin User Report Viewer) ADMN_USR_REPORT_UI (Admin User Report Viewer Role)
    Audit Report ADMN_AUDIT_UI (Admin Audit Report Viewer) ADMN_AUDIT_UI (Admin Audit Report Viewer Role)
    Notifications Broadcast ADMN_NOTIF_SEND_UI (Admin Notification Broadcast Viewer) ADMN_NOTIF_SEND_UI (Admin Notification Broadcast Viewer Role)
