3.4 System Configuration
Administrators can monitor the usage of service units and user activities through the System Configuration.
With System Configuration, administrators can view the consumption of service units. You can also view the following:
- The Audit Report to see what actions the users have performed in the application and when they have performed them
- The provisioned object storage details and the OAuth authentication details
- The production instance URL and the email ID of the login user
The components are as follows:
- Metering: Click Metering to view the usage of services using the Metering Report.
- Audit Trail Report: Click Audit Trail Report to view details such as the user's login and logout information, the action they performed, the status of the actions, and the date and time of each action.
- Component Details: Click Component Details to view details such as the Object Storage, Pre-Authenticated Request (PAR) URL, and OAuth authentication details.
- Configurations: Click Configurations to specify the instance name and the user(s) who receive emails related to operations tasks.
- Metering
View annual usage of transactions and report types. - Component Details
Use Component Details to view the object storage standard and archive details, and OAUTH authentication details. - Audit Trail Report
Use the Audit Trail Report to check user activities, including logins, added actions, their status, and associated machine names. - Configurations
Use the Configurations page to update user preferences, master encryption key, notification preferences, and allowed email domains. - Reports For Download
Parent topic: Getting Started
