3.4.3 Audit Trail Report
Use the Audit Trail Report to check user activities, including logins, added actions, their status, and associated machine names.
To generate an Audit Trail Report:
- Log in to the Admin Console.
- Go to System Configuration and click Audit Trail Report to access the Audit Trail Report page.
- Enter the following values and click Search to generate
the Audit Trail Report for all users or a specific user,
to view a specific audit trail report.
Table 3-10 Audit Trail Report Filters
Field Description User Name Enter or Search for a user name to view the report for the selected user. Action Select the Action from the list of actions to generate a report for a specific action. From Date Select the start date for the report. To Date Select the end date for the report. Action Detail Enter the string to search and filter the audit trail report for a specific action. You can get the following details from an Audit Trail Report.Table 3-11 Audit Trail Report Details
Field Description User Name The user name selected in the User Name filter field. Action Details The action selected in the Action Detail filter field. Action Code The type of action performed by the user. Status The status of the action performed. The values are Successful or Failure. Action Subtype The sub type of the action. Operation Time The date and time of the action performed. - To download the report, click Download and select your preferred file format (PDF or Excel). The report will be saved automatically to your system’s default download folder.
- Click Reset to clear all values from the filter fields and enter new search criteria.
Parent topic: System Configuration
