3.4.2 Component Details
Use Component Details to view the object storage standard and archive details, and OAUTH authentication details.
Object storage is used for data to which you require fast,
immediate, and frequent access. Archive storage is used for data which you
do not access regularly but must be retained and preserved for long periods
of time.
With every instance of the application provisioned, two
buckets are provisioned: a standard storage bucket and an archive storage
bucket. The data files that you want to load into the application for
processing must be uploaded to the standard storage bucket. The files are
automatically moved to the archive storage bucket after a period of 7
days.
To access Component Details:
Parent topic: System Configuration
