3.4.5 Reports For Download
The Reports for Download tile in the Admin Console consists of a set of pre-defined and pre-configured reports that are available for download. You can use the functions in the interface such as filter and sort to segregate the data and drill down to the details of the reports. You can then investigate the information, analyze, and export the data in CSV format.
In the Admin Console, you can download reports from Reports for Download in the System Configuration tab.
- Prerequisites
- Access Reports for Download
- Data Reporting - Data View
You can view the list of reports available for download, from the Data Entry window. Use one of the following criteria to view various reports. - View the Report Details
The Data Entry window is the interface where you can apply filter conditions (optional) on the reports and export the details. - Apply a Custom Filter to the Data View
In addition to the reports that you can view, you can also use the filter provided in the Data View window to custom filter the data in the reports for analysis purposes.
Parent topic: System Configuration
