3.4.5.3 Data Reporting - Data View
You can view the list of reports available for download, from the Data Entry window. Use one of the following criteria to view various reports.
- To search reports, click the Search field to display the search criteria pop-up.
Enter search terms in the Name, Description, or Created By fields, or use a
combination of the fields, and click Search.
The search result displays reports that match the criteria.
- To sort reports, click the Sort By drop-down and select from the options: Name,
Description, or Created By.
The reports are displayed in ascending order for the selected option.
- To view the report creation and modification details, click the More Options (three
dots) icon of a report to display the pop-up with the details for the following:
- Created By - Displays the User ID of the user who created the report.
- Created Date - Displays the date and time of the creation of the report.
- Last Modified By - Displays the User ID of the user who last modified the report.
- Last Modified Date - Displays the date and time of the last modification of the report.
- Authorizer - Displays the User ID of the authorizer who approved the report to be displayed in the window.
- Authorizer Comments - Displays the comments entered by the authorizer when approving the report to be displayed in the window.
- To view a report, mouse over the record, and the hidden menu appears. Click View
from the menu.
The details for the selected report are displayed in the Data Entry window.
Parent topic: Reports For Download
