3.4.5.4 View the Report Details
The Data Entry window is the interface where you can apply filter conditions (optional) on the reports and export the details.
You can apply the filter conditions (optional) to the reports in the Attributes Selection tab, and the results are displayed in the Data Preview tab from where you can export the report in the CSV format.
The procedure to view report details is described as follows:
- In the Data View window, click Attributes
Selection.
The Attributes Selection tab displays the details for the database table name in View Name and the table columns in Attribute Name. Expand View Name to display the columns in Attribute Name.
- Click Apply.
The Data Preview tab displays the report details. The number of records displayed in the Data Preview tab is pre-configured in the system. However, you can export the details in the CSV format by clicking Download CSV.
Parent topic: Reports For Download
