3.1.5.1 Application Users
During implementation, you can use the Create User task to create Test Service Users. By default, this task creates a minimal person record and a user account. After implementation, you should use the Hire an Employee Task to create Service Users. The Create User Task is not recommended after the implementation is complete.
For more information, see Create Application Users.
Parent topic: User Management
