3.1.3.2 Creating New Application Users
After you log in to the IAM console, the first task is to create additional user accounts.
You should assign specific user groups to the user accounts that you are creating. There are seeded user groups available with the respective services, users must be mapped to one or more of the user groups, depending on the role that they perform.
For example, you can create a user for each member of your team. Each member can then sign into the account with their credentials. You can also assign each user to specific user groups and apply specific security policies or roles to each group.
You can create the users and map the users to groups for your service. After creating the users, the users will receive a Welcome email. The users must activate their accounts and enter a new password to access the services.
You can also batch import several users using a .CSV file.
Parent topic: Managing Application Users
