3.1.3.6 Bulk Import Application Users
As an administrator, you can batch import user accounts using a .CSV file.
Before importing the user accounts, create a .CSV file that is properly formatted for the import.
To import user accounts :
  1. In the IAM Console left pane, click Users and select More Actions and select Import Users.
  2. Click Browse to locate and select the .CSV file containing the user accounts to import.
    Click Download sample file in the dialog box to download a sample file and perform the accounts upload.
  3. Verify that the path and name of the selected .CSV is updated in the Select a file to import, and click Import.
    Oracle IAM cannot import a user account if a mandatory value such as user's first name, last name, or username, is missing. In such cases, Oracle IAM will skip the incomplete account and proceed to the next account in the .CSV file.
When Oracle IAM evaluates and imports the user accounts, the imported accounts are updated in the Jobs. You can also get information related to the successful/incomplete imports if the import was not completed due to system errors.
For information on how to import and export users, groups, and Oracle application roles into and out of an identity domain, see Transferring Data.
