3.1.3.5 Map Application to the User
Once user is created and mapped to user groups, you can map the user to application.
To map the application to a user group, log in to IAM and follow these steps:
- Search for Domain.
- Select the required Domain from list.
If you are using a custom domain, select the custom domain name before proceeding with the steps below. For more information, see the Creating Custom Domain section.Figure 3-1 Domain Selection
- Select Oracle Cloud Services tab.
The screen displays the various Oracle Cloud Services.
Figure 3-2 Oracle Cloud Services
- Select the Cloud Services you are subscribed to like,
<Cloud_service_Name> xxxx-prd and
<Cloud_Service_Name> xxxx-nprd.
Where Description is mentioned as your registered Cloud Service.
- Select Users tab.
- Click Assign users, and then select the relevant
User.
Figure 3-3 Assign users
- Click Assign.
Parent topic: Managing Application Users
