3.1.3 Managing Application Users
An application user can access the subscribed cloud services, based on the roles and groups assigned to them
An administrator can create application users using IAM. They can also batch import several users
using a .CSV file.
After users are created, they are synced from IAM to the Cloud Service.
You can map the application users to existing groups based on the roles that they require and their access levels. The access level provided to an application user is based on the following:
- Groups: Groups are seeded (available out-of-the-box) by your cloud service. Administrators can also create new groups in IAM. After groups are created, they are synced from IAM to the cloud service. You can map the groups to roles using the subscribed cloud service.
- Roles: Roles are seeded by the cloud service. Administrators can also create new roles using the cloud service and assign existing functions to these new roles.
- Functions: Functions are seeded by the cloud Service. Administrators cannot create new functions; however, they can use the existing functions.
- User Summary- Application Users
View the list of existing application users in the User Summary. - Creating New Application Users
- Creating a New User Group
Create groups to manage user access to applications and resources. - Assign Groups to Users
Assign a specific group to a user, based on the roles required for the user. - Map Application to the User
Once user is created and mapped to user groups, you can map the user to application. - Bulk Import Application Users
As an administrator, you can batch import user accounts using a.CSVfile.
Parent topic: Getting Started with Oracle Cloud
