3.6.2.4 Create custom groups
You can create custom groups to cater to specific tasks within the application.
While seeded groups support a broader range of application and scenarios,
custom groups enable the precise grouping of users for targeted and specialized
application usage.
Example: You can create a user group which assigns the role
of uploading files. This way you have a dedicated user or a standalone user that is not
accessing the application but is just ingesting data.
You can create new groups using the following:
Parent topic: Groups Summary Page
