3.6.2 Groups Summary Page
The Groups Summary page shows the list of available groups. You can view the details of a group and map the group to one or more user roles.
To access the Groups Summary page:
  1. Click the Identity Management tab in the Admin Console page.
  2. Click the Groups tile, to access the Groups Summary page.
  3. Select a specific group name in the Groups Summary page and then click Details to view the associated Group ID, Group Name and Group Description.
  4. Select a group name and click Mapped Roles to view the list of roles that are mapped to the particular group.
    To map/unmap roles, refer to mapped/unmapped roles.
    To search for a specific user group, type the first few letters of the user group name that you want to search in the Search box and click Search. The results will show users matching your input.
    At the bottom of the page, adjust the number of entries displayed per page using the up and down arrows in the Records box. Use the navigation buttons, to go to the first page, last page, previous page and next page. You can also directly navigate to a specific page by entering its number in the View bar and pressing Enter
