Create and Execute Batch
To create and execute the batch:
Before executing the ADS batch, ensure the following prerequisite is met:
  • If the PBSM tenant has undergone a G2 certification update, the updated PBSM wallet must be uploaded to DFCS prior to batch execution.
  • If the ADS batch fails with DIE0021 - Unknown exception occurred and the underlying log error is ORA-01723, see Datatype Requirements for Custom ADS Mappings.
  • If the wallet is not updated post-G2 certification, all ADS batch runs will fail regardless of data availability. Contact Oracle Support to complete the wallet upload.
  1. From the LHS menu, navigate to Operations and Processes, select Scheduler, and then select Define Batch. For more details, see Define Batch.
  2. From the LHS menu, navigate to Operations and Processes, select Scheduler, and then select Define Task. For more details, see Adding a Task.
    Refer to the following table for Component and Parameters to be defined for different tasks.
    Table 5-10 Components and Parameters
    Component Parameters Target Tables
    PBSM_DFCS_Data_Transfer_instruments
    ADS Id: This displays list of data connectors available. Select one value from LOV.
    Data File Specification Id: This displays list of seeded and user defined DFS definitions. Select one relevant value for the selected ADS.
    Data Source Id: This displays members of ‘Instrument Data Source’ dimension. Select one value from LOV. Instrument data belonging to this source only will be moved from DFCS to PBSM.
    Optional Input: This can be used to specify any other input parameter in JSON Object/String.
    Stage Assets
    Stage Liabilities
    Stage Derivatives
    Stage Fee Based Services
    Stage Loan Commitments
    Stage Off Balance Sheet
    PBSM_DFCS_Data_Transfer_Dimensions
    Loads dimension members, attributes, and hierarchies from staging dimension tables into the dimension tables.
    PBSM_DFCS_Data_Transfer_ExchangeRates
    Rate Data Source Id: This displays members of ‘Rate Data Source’ dimension. Select one value from LOV. Data belonging to this source only will be moved from DFCS to PBSM.
    Loads stage and processing tables for exchange rates.
    PBSM_DFCS_Data_Transfer_InterestRates
    Loads stage and processing tables for interest rates.
    PBSM_DFCS_Data_Transfer_InstrumentSupplementary
    Stage Account Index History
    Stage Account Rate Tiers
    Stage Embedded Options Schedule
    Stage Payment Schedule
    Stage Interest Rate Schedule
    PBSM_DFCS_Data_Transfer_Transaction_Summary
    Data File Specification Id: This displays the list of DFS rules defined for a Staging table. Select one relevant value for the selected ADS.
    Data Source Id: This displays members of ‘Transaction’ dimension. Select one value from LOV. Instrument data belonging to this source only will be moved from DFCS to PBSM.
    Optional Input: This can be used to specify any other input parameter in JSON Object/ String.
    Stage Asset Transaction
    Stage Liability Transaction
    Stage Fee Based Transaction
    Stage Off Balance Sheet Transaction
    PBSM_DFCS_Data_Transfer_Customer
    Data Source Id: This displays members of ‘Customer’ dimension. Select one value from LOV. Instrument data belonging to this source only will be moved from DFCS to PBSM.
    Loads stage and processing tables for customer data.
    PBSM_DFCS_Data_Transfer_Management_Ledger
    Stage Management Ledger
    PBSM_DFCS_Data_Transfer_EconomicInd
    Rate Data Source Id: This displays members of ‘Transaction’ dimension. Select one value from LOV. Instrument data belonging to this source only will be moved from DFCS to PBSM.
    Loads stage and processing tables for economic indicators.
    PBSM_DFCS_Data_Transfer_VolatilityRates
    Loads stage and processing tables for volatility rates.
    PBSM_DFCS_Data_Transfer_VolatilitySurface
    Loads stage and processing tables for customer volatility surface rate history.
  3. Select the seeded batch and click Edit Parameters. In the Dynamic Parameters pop-up window, change the date to the relevant As-of-Date, and then save the batch.
  4. From the LHS menu, navigate to Operations and Processes, select Scheduler, and then select Execute Batch. For more information, see Schedule Batch.
  5. From the LHS menu, navigate to Operations and Processes, select Scheduler, and then select Monitor Batch. For more information, see Monitor Batch.
  6. Select the Batch, MISDATE and the Batch name. Select the latest execution and click Start Monitor.
