3.1.7.4 Invoke the API using the Access Token
After creating an access token using OAUth Client ID and Client secret, you can invoke the Specific API.
To invoke the API using the generated Access Token, refer to the following example executed using cURL Commands in the CLI Tool:
curl -iL -H "Authorization: Bearer <access token>" -H "Content-Type: <content_type>" -d "<request_body>" --cacert <certificate(.pem)> -X <http_verb> <api_url>
curl -iL -H "Authorization: Bearer <AUTH_TOKEN>"
-H "Content-Type: application/json" -d "{\"type\":\"files\",\"data\":[{\"fileName\":\"testtoken\",\"mimeType\":\"text/plain\",\"fileSize\":
123}]}" --cacert outcert.pem -X POST https://<OCI-URL>/<TENANT><APP_ID>/dsa/utils/getObjStoreParUrlParent topic: Ways to Generate Access Token
