3.1.7.3.5 Refresh Token Grant Type
When to use: To obtain a new access token without requiring user login.
- New tokens issued without user intervention.
- Ideal for maintaining long-running sessions securely.
- Refresh token validity is managed by IDCS configuration.
Sample code
curl --location 'https://<idcs_domain>/oauth2/v1/token' |\
--header 'Content-Type: application/x-www-form-urlencoded' \
--data-urlencode 'grant_type=refresh_token' \
--data-urlencode 'refresh_token=<your_refresh_token_generated_by_authorization>' \
--data-urlencode 'scope=urn:opc:idm:__myscopes__'
Sample code with mTLS
curl --location 'https://<idcs_secure_domain>/oauth2/v1/token' \
--cacert ./ca.crt \
--cert ./client.crt \
--key ./client.key \
--header "Authorization: Basic <base64Encoded clientid:secret>" \
--header 'Content-Type: application/x-www-form-urlencoded;charset=UTF-8' \
--data-urlencode 'refresh_token=<your_refresh_token_generated_by_authorization_grant_type>' \
--data-urlencode 'scope=urn:opc:idm:__myscopes__'Sample response
{ "access_token": "eyJraWQiOiJrZXkxIiwiYWxnIjoiUlMyNTYifQ...",
"refresh_token": "9b53e4a2-xxxx-xxxx-xxxx-xxxx", "token_type":
"Bearer", "expires_in": 3600, }
For more details, see Refresh Token Grant Type.
Parent topic: Generate Access Token Using Different Grant Types
