Refresh the Extension from DFCS
After subscribing to Application Data Services (ADS), you may need to apply extensions to include additional data elements or custom mappings. The following steps outline how to verify, extend, and execute the required processes.
When creating Placeholder Columns (PLC) for an ADS extension, use the target column name of the registered PLC column consistently across all source tables. PBSM does not support multiple logical names for the same PLC column. If a PLC column is created in PBSM, the same PLC column must be used for all applicable tables. Follow the same approach when creating PLC columns from the DFCS tenant.Check for Extension (PBSMCS - Subscriber)
- After completing the ADS Extension in the DFCS setup, click Check for Extension. A confirmation message appears: Do you want to proceed with the extension?
- Click Confirm to proceed.
- Then click Submit to finalize the confirmation.
Refresh ADS
- Click Extend ADS to trigger the extension of Application Data Services.
- This updates the existing process specific to the extensions.
