5.1.3 Using Scenario Conversion Utility for ASC
Scenario Conversion Utility (SCU) converts BD scenarios to Compliance Studio notebooks for the scenarios and respective thresholds.
The utility converts only BD AML scenarios to Compliance Studio notebooks based on the rule matcher algorithm.Prerequisites
- Ensure that the OFS Compliance Studio v8.1.2.8.0 is installed and running.
- Make sure that all the Compliance Studio patches are applied.
- Ensure that the OFS BD v8.1.2.*.* is installed and running.
- Ensure that the following tables and sequence exist in the
Compliance Studio Schema:
- Tables:
- ds_notebook
- ds_paragraph
- Sequence:
- seq_paragraph
- Tables:
Calendar Notebook
The calendar notebook is used to set calendar information and processing batch date for execution of the scenario notebook.
Import SCU_Set_Calendar.dsnb notebook
into the sandbox workspace and pointing to the non-prod BD atomic schema.
The following jars are available in the
<OFS_COMPLIANCE_STUDIO_INSTALLATION_PATH>/
deployed/ficdb/Scenario-Conversion-Utility/db_tools/lib directory.
dbtools.jarkddcore.jarlog4j-api-<version>.jarlog4j-core-<version>.jar
This section is applicable only if you are using Scenario Conversion Utility and Automated Scenario Calibration use case.
