9.4 Using Manual Decisioning
The Manual Decisioning allows you to make manual decisions on similarity edges in the Global Graph and matches for Entity Resolution, where the score is between the manual and automatic thresholds set on the Match Ruleset page.
- Entity Resolution (CSA8xx): If the decision is approved, the match is added to the probable groups for merging in the Entity Resolution process. If the decision is rejected, it is not considered in probable groups.
- Global Graph: If the decision is approved, the match edge will be moved to Global Graph. The match edge will not be part of the Global Graph if the decision is rejected.
You can specify your Manual Threshold on the Match Ruleset Details page for Manual Decisioning.
- On More menu, click Manual
Decisioning. The Manual Decisioning page is displayed.
The role icons are at the top-right corner, the 1st is Request User, and the 2nd is Approver User. The number of icons will be based on user privileges. If both icons are shown, you can choose whether to make a decision as an Request User or Approver User.
- You must select the following to display the records on the page:
- Manual Decision Type
- Select Pipeline / Select Graph
- Data Source Type
Other than Graph, records will be displayed only when you select the Data Source Type for Entity Resolution (CSA8xx) (ER Type).
The records on the Manual Decisioning page will be displayed based on the selection of Manual Decision Type. The Data Source Type field is applicable only when ER Type is selected as Entity Resolution (CSA8xx).Note:
Any manual actions performed in the UI will undergo the Data Survival rule and data will be persisted accordingly.- New: Where no decision has yet been made
- Pending Approved: Where Request User has made an approve decision and this is to be confirmed or rejected by a Approver User
- Pending Rejected: Where Request User has made a reject decision and this is to be confirmed or rejected by a Approver User
- Approved: Where the decision has been approved
- Rejected: Where the decision has been
rejected
For more details, see the Workflow for Manual Decisioning section.
Figure 9-15 Manual Decisioning with Records
By default, ten edges or matches are displayed per page. Click the Next arrow to view the next set of edges or matches.
- Source Entity Type (Entity Resolution (CSA8xx))/Source Node Type (Graph)
- Target Entity Type (Entity Resolution (CSA8xx))/Source Node Type (Graph)
- Advanced Search
Customizing View on the Manual Decisioning
- Select any column on the page.
- Right-click and the following options are displayed:
- Columns: You remove and add the column form list.
- Sort Ascending: You can sort the edges on the page in Ascending order.
- Sort Descending: You can sort the edges on the page in Descending order.
- Resize Column: You can resize the column by specifying the column width.
Applying Filter on the Edges
- Source Entity Type (Entity Resolution (CSA8xx))/Source Node Type (for Graph): Select the source from the list. It filters the edges based on the list under the Source column.
- Target Entity Type (Entity Resolution (CSA8xx))/Source Node Type (for Graph): Select the target from the list. It filters the edges based on the list under the Target column.
- Advanced Search: You can filter in which the recodes
search criteria as specified. For more details, see the Searching for Manual Decisions section.
You can apply all the filters in parallel. It considers source, target, and search criteria specified in Advanced Search. It uses AND logic. For example,- Source Node Type/Source Entity Type is the customer
- Target Node Type/ Target Entity Type is customer
- Advanced Search: The source Name is GRAF
- The column names (Source and Target) are replaced with selected Source and Target values from the drop-down list.
- You can drag and drop the columns on the page to change the order.
The view edge is different for Graph and Entity Resolution (CSA8xx).For more information, see the Viewing Edges from the Source section.
