14.16 Configuring Case Risk Values
This section describes how to configure Case Risk Values.
This parameter allows deployment level configuration of the minimum and maximum range of risk values during add and edit feature in Case related business tabs.
To modify the case risk value, follow these steps:
- Open the Manage Common Parameters screen.
- Select Used for Design from the Parameter Category drop-down list.
- Select Case Risk Values from the Parameter Name drop-down list.
- Editthe required parameter details and click Save. A confirmation dialog box appears with the message: Would you like to Save these actions?
- Click OK. A dialog box appears with the message: Update Operation Successful.
- Click OK. The Manage Common Parameters page is displayed.
Table 14-4 Configuring Case Risk Values
| Attribute | Description |
| Min Risk Value | Will define the minimum value of all the types of risks; will have a default value of -2. |
| Max Risk Value | Will define the maximum value of all the types of risks; will have a default value of 10. |
