3.1 System Requirements
The following applications are required to run the OFS ECM application:
The following table describes the versions of various operating systems.
Table 3-1 Configurations Supported for Java 8: Operating System
| Operating System | Version |
| Oracle Linux / Red Hat Enterprise Linux(x86-64) |
Note: Same version of RHEL is supported. |
| Oracle Solaris (SPARC) | 11.3+- 64 bit |
| Shell | KORN Shell (KSH) |
If the operating system is RHEL, install the package lsb_release with one of the following commands by logging in as root user:- yum install redhat-lsb-core
The following table describes the Java Runtime Environment.
Table 3-2 Configurations Supported for Java 8: Java Runtime Environment
| Oracle Linux / Red Hat Enterprise Linux | Oracle Java Runtime Environment (JRE) 1.8.x - 64 bit |
| Oracle Database Server and Client |
Operating System or Version:
- V 11.1.2.1+ (Server and Client) with Oracle 11g Database
- V 11.1.2.3+ (Server and Client) with Oracle 12c Database
- V 11.2.0.3+ with Oracle 11g Database
- V 12.1.0.1+ with Oracle 12c Database
The following table describes the various operating systems with versions
for Web Server or Web Application Server
Table 3-3 Configurations Supported for Java 8: Web Server or Application Server
| Oracle Linux / Red Hat Enterprise Linux/ IBM Solaris |
OFSAA Infrastructure web component deployment on Oracle WebLogic Server with Oracle JRockit is not supported. For deployment on Oracle WebLogic Server (64 bit) with Java 8, download from My Oracle Support (MOS).The following table describes the desktop requirements.
Table 3-4 Desktop Requirements
| Particulars | Version |
| Operating System | Windows 10 |
| Browser |
Turnoff Pop-up blocker settings. |
| Office Tools |
| Screen Resolution | Minimum screen resolution & Scaling must be 1366 * 768 with 100% scaling. |
The following table describes the directory services.
Table 3-5 Other Software
| Particular | Version |
| Directory Services | OFSAAI is qualified on both OPEN LDAP 2.2.29+ and Oracle Internet Directory v 11.1.1.3.0. However, it can be integrated with other directory services software such as MS Active Directory. |
- Configuration of Directory services software for OFSAAI installation is optional.
- Open LDAP must be installed on MS Windows Server machine.
