28.6 Executing the Credit Score Model and Probability of Default Model T2Ts using PMF
The T2Ts are a part of Financial Services Data Foundation Sourced Run. The process can be executed through the out-of-the-box standard Run, which is Financial Services Data Foundation Execution Run. For more information, see the section Executing Run through Process Modelling Framework in OFSDF.
When executing through Run, the RUNSkey will be auto-generated and stamped against each record.
