2.1 Cash Flow Edits Summary Page
This page is the gateway to all Cash Flow Edits Rules and related functionality. You can navigate to other pages relating to Cash Flow Edits Rules from this point. The Cash Flow Edits Summary Page displays the following columns.
Table 2-1 Cash Flow Edits Rule – Fields and Descriptions
Field Description
Rule Id Displays the code of Cash Flow Edits Rule.
Rule Name Displays the Cash Flow Edits Rule's short name.
Group Displays the Group of Cash Flow Edits Rule.
Condition Columns Displays the Columns on which of Cash Flow Edits Rule is made.
Last Modified By Displays the Name of the user who last modified the Cash Flow Edits Rule.
Last Modified Date Displays the Date and Time when Cash Flow Edits Rule was modified last.
Status Displays the Status of Cash Flow Edits Rule.
Is Editable Displays the editable status of Cash Flow Edits Rule.
Is User Defined Displays the user defined status of Cash Flow Edits Rule.
Action Displays the list of actions that can be performed on the Cash Flow Edits Rule. For more information, see Cash Flow Edits Rule – Icons and Descriptions.
Figure 2-1 Cash Flow Edits Summary Page
The Action column on the Cash Flow Edits Summary Page offers several actions that allow you to perform different functions. The following actions are available for the Cash Flow Edits Rule:
Table 2-2 Cash Flow Edits Rule – Icons and Descriptions
Field Description
Add Click Add icon to build a new Cash Flow Edits Rule.
Multiple Delete Select one or more rules in the table and then click the (-) icon at the top right of the summary page to delete more than one rule at the same time.
Help Click Help icon to view the Cash Flow Edits Rule help.
View/Edit
Click on the Action icon against the Cash Flow Edits Rule and select View/Edit to view or Edit the contents of a Cash Flow Edits Rule in read/write format. Depending on user privileges the rule will open in either View or Edit mode.
Save As Click on the Action icon against the Cash Flow Edits Rule and select Save As to create a copy of an existing Cash Flow Edits Rule.
Delete Click on the Action icon against the Cash Flow Edits Rule and select Delete to delete an existing Cash Flow Edits Rule.
