Map Maintenance and Mapper Maintenance
The Map Maintenance section of the OFSAAI enables you to map Legal Entities with User Groups. The application expects you to create the Legal Entities and User Groups from the respective OFSAAI modules.
Once the required number of Legal Entities and User Groups are created, you can create Mapper Definitions from the Map Maintenance section of OFSAAI. For more details, see the Map Maintenance section in the OFS Advanced Analytics Infrastructure User Guide.
Once the Mapper definitions are created, you can define the mappings among the participating hierarchies, from the Mapper Maintenance section. For more details, see the Mapper Maintenance section in the OFS Advanced Analytics Infrastructure User Guide.
