PreviousNext
JavaScript must be enabled to correctly display this content
Upload a Model
To upload a model:
In the View Model Objectivepage, click
Add and then select Upload
Model.
The Upload Model page is displayed.
Figure 11-51 Upload Model Drawer
Select a library from the Select Library drop-down list.
When a library is selected, the Select Technique
drop-down list appears
For more details on the model library, see the Model Libraries
section.
Select the required technique from the Select Technique
drop-down list.
For more details on the model technique, see the Model Technique
section.
Enter the model code and description for the model catalog in the
Model Code and Description
fields.
Select a python runtime from the Python Runtime
drop-down list.
Enter the name of model file with the extension in the Model File
Name field.
Import the model by using the Import Archive Fileoption.
The file format must be in be a zip format.
OR
Enable the Upload from FTPSHARE option to import the model.
The file path that is entered is the zip file path that is present on the server
relative to ftpshare path, including the file.
For example:
<installation
path>/temp/models/model.zip
