5.14 Conda
Conda as a package manager helps you to find and install packages. With the capability of environment manager, you can set up a totally separate environment to run different versions of Python. In addition, you can continue to run your usual version of Python in your normal environment.
The supported version is 4.14.0.
To install the Conda, perform the following:
  1. Download the miniconda.
  2. Copy it to your server where the Conda needs to be installed.
  3. Grant execute permission to the Conda folder.
  4. Execute the following command: $ ./Miniconda3-latest-Linux-x86_64.sh
  5. Update the PATH variable with miniconda installation path:
    <install_path>/miniconda3/bin
    In the current release, the Conda feature is not supported in Solaris Operating System.
    For more details on the Roles and privileges, see MMG User Guide.
