Access Model Pipelines
The Model Pipeline window allows you to create and publish models.
To access the Model Pipeline window:
  1. Navigate to Workspace Summarypage.
    The page displays workspace records in a table.
  2. Click Launch next to corresponding Workspace to Launch Workspace.
    The MMG Dashboard window is displayed with application configuration and model creation menu.
  3. In the LHS menu, click Model Pipelines to display the Model Pipelines page.
    The window displays objectives that contain drafts and models. When you hover on the count that are next to the ID column, it displays the count of sub objectives, Drafts, Models, and Champion if available.
    Figure 10-54 Model Pipelines page
    This image displays the Model Pipelines page.
    You can switch the Model Summary page view from Flat to Hierarchical and vice-versa. Flat list is the default view in Production workspace while Hierarchical list is the default in Sandboxes.
    • Hierarchical option: The Model Management window shows the hierarchical list of the Objectives using the Hierarchical option. In the Hierarchy view, you can see the following details of the Objectives such as Objective Name, and ID.
    • Flat option: The Model Pipeline window shows the flat list of all the models (published and drafts) using the Flat option. Flat list is not objective-specific. It shows the models across all the objectives. You can search the models using the Filter by Version, Filter by Status, and All champions. You can also sort the drafts and models by Default or Latest first options.
      • In the Flat list of models, you can see the following details of the models such as Name, ID, Version, Objective ID, Objective Name, Owner, and Status.
        Figure 10-55 Model Pipelines
        This image displays the Model Pipelines.
    The following table provides descriptions for the fields and icons on the Model Pipeline page.
    Table 10-15 Fields and icons on the Model Pipeline page
    Field or Icon Description
    Model Pipeline Page Header The header that follows the global header in the application.
    Breadcrumbs Indicates the position of the current page in the Model Management hierarchy. Use breadcrumbs locator links to navigate back to higher levels in the hierarchy after you have drilled down through levels of functions.
    Click to navigate to Model Summary page.
    Click or to navigate back to Workspace Summary page.
    Create Objectives and Models Select Add to display a list with the following options:
    • Draft
    • Objective
    • Seeded Models
    To create Models, select Draft. To create Objectives, select Objective. See the Create Objective (Folders) and Create Draft Models sections for more information.
    However, if you want to know about the cycle of model creation, see the Create, Review, Approve, and Deploy a Model Section.
    Requester Displays that the logged-in user has the Requester privileges when the status is green.
    You can create a model. However, to approve and publish, the model must be reviewed by a user with reviewer privileges and approved by a user with approver privileges.
    Reviewer Displays that the logged-in user has the Reviewer privileges when the status is green.
    You can review models. However, to approve and publish, the model must be approved by a user with approver privileges.
    Approver Displays that the logged-in user has the Approver privileges when the status is green.
    You can approve models that are created and reviewed.
    Model Pipeline Page Table The table displays the objective and model records on the page.
    Objective Name Displays the name and description of the Objective
    ID Displays the ID of the objective.
    Owner Displays the owner who created the Drafts.
    This information does not display for an Objective.
    Tags Displays the tags associated with the Models or Drafts.
    Delete Objective Select to delete the model from the Confirmation dialog box. Click Delete to process or click Cancel to cancel.
    Edit Objective Select to edit the models in Data Studio. See the Edit Models section for more information.
