Pre-Conditions for a Batch Group
You can schedule the batches and set the pre-conditions within a Batch group with
frequency as Weekly, Monthly, or based on an Interval for scheduling the batches. The
batch that satisfies the configured pre-conditions are executed as part of the schedule.
Pre-Conditions can only be applied when using the Schedule option in the Schedule Batch window.Weekly
To set the pre-conditions to the batches in a batch group weekly, perform the following steps:
- In the Schedule Batch window, you can select either Once, Daily,Weekly, Monthly, or Cron Expression option based on the schedule that you want to run the batch group.
- Select the Batch Group you want from the Select drop down menu.
- Enter a Schedule Name.
- Specify the other details displayed when you are selecting Once, Daily,Weekly, Monthly, or Cron Expression.
- Click Pre-Conditions.
- In the Pre-Conditions window, specify the Batch from the drop down and from the Frequency drop down and select Weekly.
- Select the days from the Select Days drop down that you want to schedule the batch run within the selected week.
- Click Add to add the specified entry.
Pre-Conditions can be added only to one batch at a time. - Click Save.
The batch is executed based on the configured pre-conditions.
Monthly
To set the pre-conditions to the batches in a batch group monthly, perform the following steps:
- In the Pre-Conditions window, specify the Batch from the drop down and from the Frequency drop down and select Monthly.
Interval
To set the pre-conditions to the batches in a batch group based on an interval, perform the following steps:
- In the Pre-Conditions window, specify the Batch from the drop down and from the Frequency drop down and select Interval.
- Select the interval from the Custom Recurrence (Repeat every) Days drop down
The Custom Recurrence can be set maximum to 60 days. - Click Add to add the specified entry.
- The batch is executed based on the configured pre-conditions.
