You can create a new batch group in the Define Batch window and schedule and
monitor the batch group that you created.
To create a new Batch Group:
In the Define Batch window, click
Add.
The Create a New Batch window is
displayed.
Select Batch Group option.
Specify the following fields:
Name
Description
Add Batches: This is a multi-select field. You can select
the batches that you want to add to the group using this field.
Notify on mail
The Add Batches is a
multi-select field, you can select the batches that you want to add to the
Choose the desired option to notify by an e-mail the batch execution status
depending on the property selected. E-mail for the email notification is fetched
from the IDCS configuration for the logged in user.
E-mail is a mandatory field in IDCS.
The BATCH_NOTIFY_FUNCT function must be enabled to access this feature.
If it is not available for the logged in user, this field is grayed
out.
Every Time: An e-mail is triggered irrespective of the batch
status.
Never: No e-mail will be triggered.
On Error only: An e-mail is triggered only when the batch execution has
failed/Error.
On Interrupt only: An e-mail is triggered if the batch is successfully
interrupted.
Never is the default option.
Click Save.
The new Batch Group is created and displayed in the
Define Batch window.
