Delete a Batch Group
The Delete Batch option allows you to delete a Batch
that are no longer required in the system from the Define Batch
window.
To delete a Batch Group, perform the following steps:
- From the Define Batch window, click Batch Group option to list the batch groups.
- Click Delete corresponding to the Batch Group you want to delete.
- Click OK in the confirmation dialog to confirm deletion.
