To delete Objectives and Models that exist in the Objectives, follow these
steps:
Click Launch Workspace next to corresponding Workspace
to Launch Workspace to display the MMG Dashboard window
with application configuration and model creation menu.
Click Model Pipelines to display the Model
Pipelines window.
The window displays objectives that contain models and model records in a
table.
Click Action next to corresponding record
(objective/draft) and select Delete.
You can select two or more objectives or models from the records.
Click Delete to display the Delete dialog box.
Click Delete to delete or click Cancel
to cancel.
Figure 8-92 Delete Objects screen
If the Model is promoted to Production, you cannot delete the model even
it is retired.
