Execute the Production Workspace Models from Analytical Applications Infrastructure
Prerequisites
  • To execute the Production Workspace Models from AAI, log in to My Oracle Support, and search for 35250055 patch under the Patches & Updatestab, download and apply it on the OFSAAI sever.
  • Ensure the AAI Infodom and the Workspace names are same before you execute the Production Workspace Models.
To execute the Production Workspace Models from the AAI application, perform the following steps:
  1. In the AAI configuration schema, update the value for MMG_SERVICE_URL in the nextgenemf_config table with the values in the installation.
    Example: MMG_SERVICE_URL :<FQDN/IP>:<mmg_be_port>/<mmg_context_name>
    If the target application is using secured connection, import the target server certificate to the AAI application java keystore and restart the services.
  2. Restart the AAI services.
    A new component STUDIOMODEL will be available in ICC, RRF, and PMF modules for selecting the Production Workspace Models of the application.
    For more details, refer to the Component: STUDIOMODEL section of AAI User Guide.
