Manage Tasks
You can manage tasks by modifying or deleting tasks and also define task
precedence.
- Modify: Use the edit icon to modify details of existing tasks of a Batch definition such as Task Description, Task Type, Batch Service URL, and Task Service URL. You can also add a new task parameter and enable or disable existing task parameters.
- Delete: Use the delete icon to remove a task from a Batch definition from the Define Task window.
- Define Task Precedence: Task Precedence specifies the execution-flow of a Batch. Task Precedence value facilitates you to determine the order in which the tasks of a Batch are executed.
For example, consider a Batch consisting of 4 tasks. The first 3 tasks do not have
a precedence defined and hence will be executed simultaneously during the Batch
execution. But, task 4 has a precedence value as task 1 which indicates that, task 4 is
executed only after task 1 has been successfully executed.
You can set Task precedence between Tasks or define to run a Task after a set of
other tasks. However, multiple tasks can be executed simultaneously; cyclical execution
of tasks is not permitted. If the precedence for a task is not set, the task is executed
immediately on execution of the Batch.
To define the task precedence in the Define Task window:
