In the View Model Objective page, click Add
and select Build Model.
The Model Details page is displayed.
Figure 8-46 Model Details
page
Select the library from the drop-down. Currently, the supported libraries are
keras, ONNX, scikit-learn, and xgboost. For more details, see the Model Library section.
Select the required technique from the drop-down. For more details, see the
Model Technique section.
Enter the model code and description for the model.
Enter the name of model file with extension for use during Save and Load.
