In the View Model Objective page, click Add
and select Upload Model.
The Upload Model page is displayed.
Figure 8-45 Upload Model
page
Select the library from the drop-down.
For more details on the model library, see the Model Library section.
Select the required technique from the drop-down.
For more details on the model technique, see the Model Technique section.
Enter the model code and description for the Model Objective.
Enter the name of model file with extension for use during Save and Load.
Import the model using Import Archive Fileoption. File
format should in be zip format.
OR
Enable Upload from FTPSHARE option to import the model. File Path
entered is the zip file path present on the MMG Server relative to ftpshare path
including file.
