PreviousNext
JavaScript must be enabled to correctly display this content
Configure Workspace Schema
Enter schema operation and enter connection details in this window.
Figure 7-4 Workspace Schema
To configure the Workspace Schema:
Select the required schemas from the Data Schema
drop-down list. This is the actual data used for model building. You can use
multiple Data Schemas for one Meta Source. You can select an existing Schema or
add a new Schema by clicking on + icon. The data source options such as Oracle,
Hive, and File are displayed.
Figure 7-5 Data Schema
For details on adding a new
data store, see Data Store section.
Select the required options from the Kafka Topics list.
The selected Kafka topics are listed in the right side menu with the order of
selection. For more details, see Kafka Topics.
Select the required options from the API Registry list.
The selected API Registry are listed in the right side menu with the order of
selection. For more details, see API
Registry.
Select the required options from the Conda Environments
list. For more details, see Conda Environments.
