5 Execute the Production Workspace Models from Analytical Applications Infrastructure
To execute the Production Workspace Models from AAI, follow these steps:
  • To execute the MMG Production Workspace Models from AAI, log in to My Oracle Support, and search for 35250055patch under the Patches & Updatestab, download and apply it on the OFSAAI sever. It is available as a part of the ML Release.
  • Ensure the AAI Infodom and the Workspace names are same before you execute the Production Workspace Models.
  • The Logged In user should also be same as the Workspace Create user.
  1. In the AAI Configuration Schema, update the value for MMG_SERVICE_URL in the nextgenemf_config table with the values in the installation.
    Example: MMG_SERVICE_URL :<FQDN/IP>:<mmg_be_port>/<mmg_context_name>
    If the Target Application is using secured connection, import the Target Server Certificate to the AAI Application Java Keystore and restart the services.
  2. Restart the AAI services.
    A new component STUDIOMODEL will be available in ICC, RRF, and PMF modules for selecting the Production Workspace Models of the application.
    For more details, refer to the Component: STUDIO section of AAI User Guide.
