10.1.3.6 Define Tasks
The Define Tasks window displays the list of tasks associated with a specific Batch definition. You can create new tasks, edit the existing tasks or delete unwanted tasks. Additionally, you can specify task precedence for each task in Task Precedence window and click the Schedule icon to Schedule the batch.
The Define Tasks window allows you to perform the following task operations for your batch and batch group:
  • Batch
  • Batch Group
