10.1.3.5.2.3 Delete a Batch Group
The Delete Batch option allows you to delete a Batch that are no longer required in the system from the Define Batch window.
To delete a Batch Group, perform the following steps:
  1. From the Define Batch window, click Batch Group option to list the batch groups.
  2. Click Delete corresponding to the Batch Group you want to delete.
  3. Click OK in the confirmation dialog to confirm deletion.
