9.1.5.2.8 Re-run a Batch/Batch Group
You can re-run a Batch which has previously been executed. Rerun Batch facilitates you to run the Batch irrespective of the previous execution state. A new Batch Run ID is generated during the Rerun process and the Batch is executed as similar to the new Batch Run.
To re-run a batch:
  1. Click Schedule Batch from the Header panel.
    The Schedule Batch window is displayed.
  2. In the Schedule Batch window, select Re-run tab.
  3. Select the Batch or Batch Name you want to re-run from the Select Name list.
  4. Select the Batch Run ID.
  5. Click Re-run.
