9.1.5.2.7 Re-start a Batch/Batch Group
You can restart a Batch which has not been executed successfully or which has been explicitly interrupted, or cancelled, or put on hold during the execution process. By restarting a Batch, you can continue Batch execution directly from the point of interruption or failure and complete executing the remaining tasks.
To re-start a batch:
  1. Click Schedule Batchfrom the Header panel.
    The Schedule window is displayed.
  2. From the Schedule window, select Re-start tab.
  3. Select the Batch Group you want to re-start from the Select Name drop down menu.
  4. Select the Batch Run ID.
  5. Click Re-start.
