Defining System Messages
This portal is used to search for message categories and messages that appear throughout the system. An implementation may introduce messages used in custom processes or may choose to override the text for messages delivered by the product.
You can access the portal from the . You are brought to a query portal with options for searching for a specific message category or a message. Once a record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Refer to Understanding System Messages for more information.
Related Topics:
Parent Topic: Understanding System Messages
