MICROS Workstation 625/655 Primary I/O Ports
The Oracle MICROS Workstation 625 and Workstation 655 include an array of ports for a variety of connectivity options. Note that port availability varies by model.
Figure 4-2 Primary I/O Panel of the MICROS Workstation 625X/655X and 625E
Table 4-2 Oracle MICROS Workstation 625/655 I/O Ports
| Port | Description |
12V out port |
Gigabit Ethernet port (2x). The 2nd RJ45 Port can be used as dual-NIC for workstation or as a hub for network-connected peripherals. |
High speed USB ports (4x) |
Ultra high speed USB port (DisplayPort capable) |
12V powered USB port |
Customer display port. The customer display port supports existing pole displays and the Workstation 6 integrated customer display. |
Cash drawer port (12/24V selectable - 2x) Series 2 cash drawer ports are compact and feature an expanded number of pins to accommodate more options on the cash drawer interface. You can use an adapter cable for backwards compatibility to existing cash drawers. |
4-pin power Mini DIN |
24V powered USB port |
IDN port (RS422/RS232) |
RJ-45 serial ports (2x)
Parent topic: MICROS Workstation 625/655
