MICROS Workstation 625/655 Technical Specifications
The following table contains the technical specifications for the Workstation 655X. Other models may not include identical components and capabilities. Contact your Oracle MICROS representative for more information.
Table 4-3 Technical Specifications for the MICROS Workstation 655X
| Feature | Description | ||
Processor |
Intel Core i5-8265U Quad Core 1.6GHz |
Display |
Memory |
2 - SODIMM Sockets; 8GB DDR4L 2400MHz |
Storage |
Removable Recovery Media |
128/256 GB SSD. Allows rapid restore to the original factory condition. |
Operating System |
Magnetic Stripe Reader (Optional) |
Modular integrated 3-track magnetic card reader; capable of hardware encryption at the swipe. Merchantlink encryption key pre-injected. |
Modular Integrated Biometric Fingerprint Reader (Optional) |
Provides rapid identification and secure verification capabilities for recognition of individual users without requiring passwords or card swipes. |
RFID |
Integrated RFID reader for employee sign in. Reads 125 kHz and 13.56 MHz RFID tags. |
Audio |
Network |
USB |
9 Total:
Serial Ports |
3 Total Standard:
Adjustable Stand Expansion Modules (Optional) |
Powered USB Expansion Module:
Cash Drawer Ports |
2 - MICROS Series 2 cash drawer ports (12/24V selectable) |
Customer Display Port |
1 - MICROS DIN customer display port |
Power Output |
1 - 12V power out (2.5A) |
Expansion Ports |
Power Supply |
Supported Stands |
Workstation 6 Series Adjustable Stand, Workstation 6 Series wall mount, Compact Workstation 3 Series Flexible Stand, Compact Workstation 3 Series Basic Stand |
Weight |
Head unit: 5.4 lbs Adjustable Stand: 5 lbs |
Dimensions |
Workstation only: Approximately 366mm x 238mm x 42mm (14.4 x 9.37 x 1.65 inches) See Equipment Dimensions for more details. |
Operating Temperature and Humidity |
0 °C (32 °F) to 50 °C (122 °F); 90% Max relative humidity (non-condensing) |
Enclosure |
Certifications |
FCC Class A, UL, CE, TUV, RoHS, China RoHS |
Parent topic: MICROS Workstation 625/655
